Enable Protocol Independent Multicasting (PIM) on a CLIP interface so that it can participate in PIM routing.
You must globally enable PIM.
Circuitless PIM Field Descriptions
Use the data in the following table to use the Circuitless PIM tab.
Name | Description |
Enable | Enables PIM on the CLIP interface. |
Mode |
Specifies the PIM mode. |
