Configure Ethernet MSTP MSTI
Use the following procedure to configure the Ethernet MSTP MSTI parameters on a port.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure Ethernet MSTP MSTI:
    spanning-tree mstp msti <1-63> [cost <1–200000000>] [force-port-state enable] [port {sub-port]][,...][slot/all][all]}] [priority <0–240>]
Switch(config-if)# spanning-tree mstp msti 62 priority 32
Use the data in the following table to use the spanning-tree mstp msti <1-63> command.
Variable
Value
<1–63>
Specifies the instance ID.
cost <1–200000000>
Configures the path cost for the port
Enables MSTI learning for the port.
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
priority <0–240>
Configures the priority for the port. Enter the priority value (0–240) as increments of 16.
