Creating customized SaaS applications
In addition to the SaaS dictionary, you may use a customized dictionary by creating your own SaaS applications.
This additional dictionary is defined per Customer.
1 In the Application provisioning Toolbar, select Custom Saas Applications:
2 By clicking on the New button in the Custom SaaS Applications window, the creation window is displayed:
3 Enter the Name of the SaaS application. In the case of a duplicate name, the system informs you that this name already exists in the SaaS dictionary and automatically renames your customized application.
4 You may enter a detailed description of the application.
You must declare the new SaaS application through either a FQDN or a subnet, or both of them.
5 Click in the FQDNs panel and enter a Fully Qualified Domain Name according to the following format:
• https://www.extremenetworks.com/products/ => FQDN is www.extremenetworks.com
• https://www.google.com/analytics/ => FQDN is www.google-analytics.com
With HTTP, the FQDN is extracted from the URL. With HTTPS, the Common Name is used.
6 You can also click in the Subnets panel and specify a subnet for the new SaaS application (as for other applications).
7 Click OK and Apply to validate.
