Real Time Graphs
From any flow in the Detailed flows list described above, you can open a Real Time Graph which is a 12-minute window showing the evolution of the above metrics with additional polling every 10 seconds. You can open up to four graphs simultaneously.
To access the Real Time Graphs, right click on a flow and select Start Real Time Graph:
Note: Pop-up windows must not be blocked in your web browser.
A Real Time Graph is empty when it starts. You can see some data after 10 to 20 seconds.
The graph window contains four tabs, and each tab is made of 4 graphs, displayed simultaneously:
Tab
Graphs
What is shown
Avg. Delay (ms)
LAN-to-LAN (in blue) and WAN-to-WAN (in orange) average delays
Packet loss (%)
LAN-to-LAN (in blue) and WAN-to-WAN (in orange) packet losses
Avg. sessions
Average number of sessions
Throughput (kbps)
LAN-to-LAN (in blue) and WAN-to-WAN (in orange) Throughputs
LAN
Delay (ms)
LAN-to-LAN maximum (in red), average (in blue) and minimum (in green) delays
Packet loss (%)
LAN-to-LAN packet loss
Jitter (ms)
LAN-to-LAN jitter
Throughput (kbps)
LAN-to-LAN layer 3 (in blue) and layer 4 (in green) throughputs
WAN
Delay (ms)
WAN-to-WAN maximum (in red), average (in blue) and minimum (in green) delays
Packet loss (%)
WAN-to-WAN packet loss
Jitter (ms)
WAN-to-WAN jitter
Throughput (kbps)
WAN-to-WAN layer 3 throughput
TCP
SRT (ms)
Maximum (in red), average (in blue) and minimum (in green) Server Response Time
RTT (ms)
Maximum (in red), average (in blue) and minimum (in green) Round Trip Time
Retransmission (%)
TCP retransmissions
Throughput (kbps)
Layer 3 (in blue) and layer 4 (in green) TCP throughputs
Note: In case of control and/or compression, the differences between LAN and WAN values may be very different.
Exporting the graphs
By right-clicking any graph, you display a contextual menu enabling you to export the graph, either as a graph (PNG format) or as raw data (CSV format):
The frame that opens has two tabs:
• Chart, allowing to download the graph as a PNG image:
Three check boxes allow displaying or hiding the Borders, the Date and Time and the Title.
• Data, allowing to download the graph as CSV data:
