Customizing the SSL Proxy Certificate Trust Store
The
SSL Proxy Certificate Trust Store frame enables you to customize
the SSL Proxy Certificate Trust Store.
It is configured with a set of standard institutional certificates by default . You can add your own corporate CA certificates, and/or remove all those you do not need.
This frame contains three windows, accessible through three tabs:
| • | Current Domain Custom Trust Store, where you can import Trusted Certificates, enable/disable them or remove them, |
| • | Default Trust Store that shows the list of standard institutional certificates; they can be enabled or disabled, |
| • | Current Domain Trust Store Summary that displays a summary of the current Domain Trust Store. |
