Remote Visibility and Control
From the main menu, select Settings -> Remote Visibility and Control to add and manage RVC destinations.
A RVC destination means that there is no SD-WAN appliance on the related Site. ExtremeCloud SD-WAN allows traffic of an unequipped Site to be measured and controlled by the appliances of some remote equipped Sites. Only one RVC destination is authorized per Site. A RVC destination is mainly identified by one or several LAN subnet(s).
A group of remote appliances cooperate to measure the traffic (Application Visibility) and detect flow congestions (Application Control) of the RVC destination. Note that the following measurements are not done for a RVC:
measurement and control of shadow traffic (traffic between RVC destination sites) |
end-to-end bandwidth tracking |
Adding a RVC destination
1
In the General panel, enter the Name of the RVC destination. |
2
Configure the LAN of the RVC destination which includes one subnet at least: click Add Subnet twice and enter the Subnet IP Address and Prefix Length (24). |
4
Configure the WAN linked to the RVC destination by selecting the WAN Service from the list, if it has been already define, otherwise, create the WAN Service. |
Note that the 'Not Specified' option corresponds to any network or a combination of several networks.
5
In the Access Bandwidth fields, define the up and down throughput (in kilobits per second) allocated to the WAN. |
6
Optionally select an Overlay; you can also create one. |
7
Validate your input by clicking Done. |
All RVC destinations are listed in the Remote Visibility and Control list. You can enable/disable or delete them.
