Removes the port configuration that causes multicast group traffic to be forwarded, even if no IGMP leaves have been received on the port.
| vlan_name | Specifies a VLAN name. |
| port_list | Specifies one or more ports or slots and ports. |
| ip_address | Specifies the multicast group IP address. |
| all | Delete all the static groups. |
N/A.
This command is used to remove a static IGMP group entry created on a VLAN or on a port. Use this command to remove a static group entry created by the following command:
configure igmp snooping vlan vlanname ports portlist add static group ipaddressThe following example removes a static IGMP entry that forwards the multicast group 224.34.15.37 to the VLAN marketing on ports 2:1-2:4:
configure igmp snooping marketing ports 2:1-2:4 delete static group 224.34.15.37
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IGMP snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.
