Displays BGP specific memory usage.
detail | Displays detail information. |
memoryType | Specifies the memory type usage to display. |
N/A.
To see the memory types that you can display, enter the show bgp memory command without any attributes.
The following command displays detailed BGP output for a specific memory types:
Switch.16.3 # sh bgp memory BGP Memory Information ------------------------------------------------------------------------------------------------------------ Current Memory Utilization Level: GREEN ------------------------------------------------------------------------------------------------------------ Type AN AB ------------------------------------------------------------------------------------------------------------ Callbacks 1141 17039828 Buffers 19 8456 Memory Utilization Statistics: ------------------------------------------------------------------------------------------------------------ Module Type Module Id MemType Name Size AN/AB/HN/HB ------------------------------------------------------------------------------------------------------------ PCT_NBASE_ROOT 0x0000000000 16777219 MEM_PROCESS_ENTRY 212 8/1696/8/1696 PCT_NBASE_ROOT 0x0000000000 16777230 MEM_NBB_DIAGS_BLOCK 3212 8/25696/8/25696 PCT_NBASE_ROOT 0x0000000000 16777233 MEM_UNFORMATTED 1508 1/1508/1/1508 PCT_NBASE_ROOT 0x0000000000 50528257 0x0003030001 732 1/732/1/732 PCT_NBASE_ROOT 0x0000000000 50921473 0x0003090001 2004 1/2004/1/2004 PCT_NBASE_ROOT 0x0000000000 52232193 0x00031d0001 1508 1/1508/1/1508 PCT_NBASE_ROOT 0x0000000000 1090584577 MEM_QBRM_LOCAL 9660 2/19320/2/19320 PCT_NBASE_ROOT 0x0000000000 1090650113 MEM_QBNM_LOCAL 1508 2/3016/2/3016 PCT_NBASE_ROOT 0x0000000000 1107361793 MEM_QVB_LOCAL 3076 1/3076/1/3076 PCT_SCK 0x0001109000 16777220 MEM_NBB_POOL_CB 108 9/972/9/972 PCT_QVB 0x0001104000 1107361803 MEM_QVB_RV_REM_CB 60 6/360/6/360 PCT_QVB 0x0001104000 1107361806 MEM_QVB_AS_PATH_CB 60 4/240/4/240 PCT_QVB 0x0001104000 1107361807 MEM_QVB_RTM_CB 516 1/516/1/516 Flags : AN - Number of Allocations, AB - Total Allocation in Bytes : HN - Number of High Water Marks for Allocation, HB - Total High Water Mark Allocations in Bytes t16.3 # sh bgp memory 1107361807 BGP Memory Information ------------------------------------------------------------------------------------------------------------ Current Memory Utilization Level: GREEN ------------------------------------------------------------------------------------------------------------ Type AN AB ------------------------------------------------------------------------------------------------------------ Callbacks 1141 17039828 Buffers 19 8456 Memory Statistics for MEM_QVB_RTM_CB: ------------------------------------------------------------------------------------------------------------ MemId Size AN AB ------------------------------------------------------------------------------------------------------------ 001107361807 516 1 516 Flags : AN - Number of Allocations, AB - Total Allocation in Bytes : HN - Number of High Water Marks for Allocation, HB - Total High Water Mark Allocations in Bytes
This command is updated to reflect L3 VPN changes in ExtremeXOS 15.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
