This command applies a policy map for routes imported to the FIB from all IS-IS router processes on this virtual router.
| policy-map | Specifies the policy to apply. |
| none | Removes any policies assigned to this virtual router. |
None.
nlri IPv4-address/mask-len IPv6-address/mask-len
route-origin [isis-level-1 | isis-level-2 | isis-level-1-external | isis-level-2-external]
cost
The following command applies the IS-IS policy policy2 to the virtual router:
configure isis import-policy policy2
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
