show bootprelay dhcp-agent information circuit-id port-information
show bootprelay dhcp-agent information circuit-id port-information ports all
Description
Displays the circuit ID sub-option that identifies the port for an incoming DHCP request.
Syntax Description
Default
N/A.
Usage Guidelines
None.
The following command displays the circuit ID port_info value for all ports:
Switch.12 # show bootprelay dhcp-agent information circuit-id port-information ports all
Port            Circuit-ID Port information string
1               1001
2               1002
3               extreme1
4               1004
5               1005
6               1006
7               1007
8               1008
9               1009
10              1010
11              1011
12              1012
48              1048
49              1049
50              1050
Note: The full Circuit ID string has the form '<Vlan Info>-<Port Info>'
This command was first available in ExtremeXOS 12.4.
Platform Availability
