Configures the time after which dynamic IP Network Address Translation (NAT) entries that are not active are removed.
| ip | Specifies Internet Protocol (IP). |
| nat | Specifies NAT. |
| aging-time | Configures the time after which dynamic IP Network Address Translation (NAT) entries that are not active are removed. |
| minutes | Specifies the aging time in minutes. The default is 20 minutes. The range is 10 to 3,000 minutes. |
| none | Specifies not perform aging of NAT entries. |
By default, the aging time is 20 minutes.
The following example configures the NAT aging time to 45 minutes.
# configure ip nat aging-time 45
This command was first available in ExtremeXOS 31.2.
This command is available on the switches that support the IP NAT feature. For information about which switches support this and other features, see the Switch Engine v33.1.1 Licensing Guide document.
