Displays the configuration for the guest VLAN feature.
| vlan_name | Specifies the name of a guest VLAN. |
| vlan_list | Specifies the guest VLAN list of IDs. |
N/A.
Use this command to display the guest VLANs configured on the switch.
If you specify the vlan_name, the switch displays information for only that guest VLAN.
The following sample output displays the local network login list:
# show netlogin guest-vlan Port Guest-vlan Vlan --------------------------------------- 5:1 Disabledgvl1 5:2 Enabledgvl2 5:3 Disabledgvl3 5:4 Enabledgvl4
This command was first available in ExtremeXOS 11.6.
The vlan_list variable was added in ExtremeXOS 16.1.
