enable ip-option record-route
Description
Enables processing of the record route IP option in the IPv4 packet header.
Syntax Description
Default
Enabled.
Usage Guidelines
IP option record-route (IP option 7) means that each router along the path should add its IP address into the options data.
Enabling means that the switch adds itself into the IP options header when the record route IP option is enabled in a packet that is transiting the switch.
The following example enables processing of the record route IP option:
Platform Availability
