Adds an SNMPv3 community entry.
| hex_community_index | Specifies the row index in the snmpCommunity table as a hex value supplied as a colon separated string of hex octets. |
| community_index | Specifies the row index in the snmpCommunity Table as an ASCII value. |
| hex_community_name | Specifies the community name as a hex value supplied as a colon separated string of hex octets. |
| community_name | Specifies the community name as an ASCII value. |
| hex_user_name | Specifies the USM user name as a hex value supplied as a colon separated string of hex octets. |
| user_name | Specifies the USM user name as an ASCII value. |
| tag | Specifies the tag used to locate transport endpoints in SnmpTargetAddrTable. When this community entry is used to authenticate v1/v2c messages, this tag is used to verify the authenticity of the remote entity.hex_transport_tag—Specifies a hex value supplied as a colon separated string of hex octetstransport_tag—Specifies an ASCII value |
| volatile | Specifies volatile storage. |
N/A.
Use this command to create or modify an SMMPv3 community in the community MIB.
Community name as a blank string is not accepted.
switch # configure snmp add community readonly extreme store-encrypted
switch # show snmpv3 community
Community Index : extreme
Community Name : hys{fnj (encrypted)
Security Name : v1v2c_ro
Context EngineID : 80:00:07:7c:03:00:04:96:27:b6:63
Context Name :
Transport Tag :
Storage Type : NonVolatile
Row Status : Active
switch # configure snmp add community readwrite extreme123
Context Name :
Transport Tag :
Row Status : Active
Community Index : extreme123
Community Name : extreme123
Security Name : v1v2c_rw
Context Name :
Transport Tag :
Row Status : Active
switch # show configuration "snmp"
# Module snmpMaster configuration.
configure snmpv3 add community extreme encrypted name hys{fnj user v1v2c_ro
configure snmpv3 add community extreme123 name extreme123 user v1v2c_rw
The following command creates an entry with the community index comm_index, community name comm_public, and user (security) name v1v2c_user:
configure snmpv3 add community comm_index name comm_public user v1v2c_user
This command was first available in ExtremeXOS. 10.1.
The hex_community_index, hex_community_name, hex_user_name, and hex_transport_tag parameters were added in ExtremeXOS 11.0.
