Deletes a trusted DHCP server from the switch.
| vlan_name | Specifies the VLAN name. |
| ip_address | Specifies the IP address of the trusted DHCP server. |
| dynamic | Configuration options for dynamically created VLANs. |
| vlan_id | VLAN ID tag between 1 and 4,094. |
N/A.
Use this command to delete a trusted DHCP server from the switch.
To display the DHCP snooping configuration settings, including DHCP trusted servers if configured, use the following command:
show ip-security dhcp-snooping {vlan} vlan_nameTo display any violations that occur, including those on the DHCP trusted servers if configured, use the following command:
show ip-security dhcp-snooping violations {vlan} vlan_nameThe following command deletes a trusted DHCP server from the switch:
configure trusted-servers vlan purple delete server 10.10.10.10 trust-for dhcp-server
This command was first available in ExtremeXOS 11.6.
Dynamic VLAN and VLAN ID options added in ExtremeXOS 30.2.
