Requests information from a multicast router.
| router_address | Specifies the unicast IP address of the router for which you want information. |
| from_address | Specifies the unicast IP address of the interface where the mrinfo request is generated. |
| seconds | Specifies a maximum time to wait for a response. The range is 1–30 seconds. |
| multi_resp_timeout | Specifies a maximum time to wait for additional responses after the first response is received. The range is 0 to 3 seconds. |
| vrname | Specifies a VR name. |
router_address: One of the local interface addresses.
from_address: IP address of interface from which the mrinfo query is generated.
timeout: 3 seconds
multiple-response-timeout: 1 second
vr: DefaultVR
The last column of the mrinfo command output displays information in the following format:
[Metric/threshold/type/flags]
This information is described in detail in the Syntax Description..
| Data | Description |
| Metric | This should always be 1 because mrinfo queries the directly connected interfaces of a device. |
| Threshold | This should always be 0 because the threshold feature is not supported in ExtremeXOS software. |
| Type | The type specifies the multicast protocol type. Because the ExtremeXOS software only supports PIM, this value is always pim. |
| querier | The querier flag indicates that the queried router is the IGMP querier. |
| leaf | The leaf flag indicates that the IP interface has no neighbor router. |
| down | The down flag indicates that the interface link status is down. |
The following command requests information from multicast router 1.1.1.1:
Switch.1 # mrinfo 1.1.1.1 1.1.1.1 [Flags:PGM] 2.2.2.1 -> 2.2.2.2 [1/0/pim/querier] 1.1.1.1 -> 0.0.0.0 [1/0/pim/querier/leaf] 8.8.8.1 -> 8.8.8.4 [1/0/pim/querier] 3.3.3.1 -> 0.0.0.0 [1/0/pim/down]
This command was first available in ExtremeXOS 12.4.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
