disable bgp aggregation
Description
Disables BGP route aggregation.
Syntax Description
Default
Disabled.
Usage Guidelines
Route aggregation is the process of combining the characteristics of several routes so that they are advertised as a single route. Aggregation reduces the amount of information that a BGP speaker must store and exchange with other BGP speakers. Reducing the information that is stored and exchanged also reduces the size of the routing table.
Use this command to disable BGP route aggregation.
The following command disables BGP route aggregation:
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
