This is a script command and operates only in scripts or on the command line when scripting is enabled with the following command: enable cli scripting {permanent}.Displays the current session variables or the named variable.
| varname | Displays the variable specified, if present. |
N/A.
Use this command to see the list of current session variables. The display includes the variable name and value.
The output of this command is similar to the following:
Switch.7 # show var ---------------------------------------- Count : 4 ---------------------------------------- ------------------------------------------------------------------ variableName variableValue -------------------------------- -------------------------------- CLI.SESSION_TYPE serial CLI.USER admin STATUS 0 x 66 ------------------------------------------------------------------
This command was first available in ExtremeXOS 11.6.
