Displays the output of various show commands to assist in monitoring and troubleshooting the switch; use only in conjunction with Extreme Networks Technical support.
| all | Indicates all available show command output to be displayed. |
| area | Specifies one tech support area. For example, if you want to view STP information, enter stp. |
| detail | Specifies more detailed information. |
| logto [file] | Instructs the switch to log the show tech-support output into a file located in the switch‘s internal memory. The default file name is show_tech.log.tgz. |
| bundle | Selects collecting debug commands for specified functional areas. |
| bundle_name | Specifies the debug bundle name. |
| monitor | Selects executing a debug bundle multiple times. |
| num_iterations | Specifies the number of times to execute the debug bundle. |
| interval | Specifies setting the interval between successive executions of the debug bundle. |
| seconds | Sets the delay in seconds between successive intervals. The default is 300s. |
The default interval between multiple executions of a debug bundle is 300s.
Use this command only under the guidance of Extreme Networks Technical Support personnel to view your switch configurations and to troubleshoot the switch.This information can be useful for your technical support representative if you experience a problem.
Depending on the software version running on your switch, the configurations running on your switch, and the type of switch you have, additional or different show command and configuration output may be displayed.
Debug bundles are JSON files that provide predefined modules to common problems that can be executed when an issue occurs. You can search for a bundle that best matches your issue, and then execute that relevant bundle that matches your problem. For a list of bundles, use the command show tech-support help, or view information about this feature in the Troubleshooting chapter in the Switch Engine v33.1.1 User Guide .
The following example collects debugging information using a debug bundle named "l3" to run 5 times:
# show tech-support bundle l3 monitor 5
The command name and command syntax was modified in ExtremeXOS Release 15.4 from show tech to show tech-support.
Fabric attach mapping information was added in ExtremeXOS 22.4.
Debug bundle information was added in ExtremeXOS 30.6.
