Enables the IGMP snooping fast leave feature on the specified VLAN.
| name | Specifies a VLAN. |
Disabled.
The fast leave feature operates only with IGMPv2.
To view the fast leave feature configuration, use the show configuration msmgr command. This show command displays the fast leave configuration only when the feature is enabled.
The following example enables the IGMP snooping fast leave feature on the default VLAN:
enable igmp snooping "Default" fast-leave
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IGMP snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.topic/ph "/>
