Configures the shutdown priority for a BGP neighbor.
remoteaddr | Specifies the IPv4 or IPv6 address of a BGP neighbor. |
all | Specifies all IPv4 and IPv6 neighbors. |
number | Specifies the shutdown priority. The range is 0 - 65,535. |
The default value is 1024.
This command is not currently supported, and is not recommended for use.
Higher priority values lower the chance of a BGP neighbor to be automatically disabled in case BGP or the system goes to a low memory condition.
The following command configures the shutdown priority of the BGP neighbor 10.0.20.1 to 500:
configure bgp neighbor 10.0.20.1 shutdown-priority 1000
Support for IPv6 was added in ExtremeXOS 12.6 BGP.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
