Enables or disables stacking auto-discovery.
| stacking-support | Configures stacking support. |
| auto-discovery | Configures auto-discovery for stacking. |
| disable | Disables stacking auto-discovery. |
| enable | Enables stacking auto-discovery. (Default) |
Stacking auto-discovery is enabled by default.
For ExtremeSwitching 5420 and 5520 series switches, stacking auto-discovery allows the switch to detect the type of cable inserted into the stack ports and automatically update the stack port speed while the switch is booting up.
To view stacking auto-discovery status, use the command show stacking-support.
The following example disables stacking auto-discovery:
# configure stacking-support auto-discovery disable
This command was first available in ExtremeXOS 30.3.
This command is available on ExtremeSwitching 5420 and 5520 series switches.
