Adds or removes a descriptive name to a slot.
| slot | Specifies a specific port extender by slot number. |
| description | Specifies naming the BPE at the designated slot. |
| slot_description | Name for the BPE at the designated slot (max. of 64 characters long). |
| none | Specifies removing the current name assigned to the BPE at the designated slot. |
N/A.
To remove a name from a slot, use the none option.
The slot name can be up to 64 characters long.
The following example applies the name "Accounting Dept" to the BPE at slot 100:
configure slot 100 description Accounting Dept
This command was first available in ExtremeXOS 22.5.
