Unconfigures an IPv6 address/prefix route from a tunnel.
| tunnel_name | Specifies an IPv6 tunnel. |
| ipv6_address_mask | Specifies an IPv6 address / IPv6 prefix length. |
N/A.
Use this command to unconfigure an IPv6 address/prefix route from the specified tunnel.
The following example unconfigures the 6in4 tunnel "link39" with the address 2001:db8::1111/64
unconfigure tunnel link39 2001:db8::1111/64
This command is available on the platforms listed for the IPv6 interworking feature in the Switch Engine v33.1.1 Licensing Guide document.ss="- topic/ph "/>
