Displays information about an This command is available on all Universal switches supported in this document..
peer_name |
Specifies an alpha numeric string identifying the MLAG peer switch. |
N/A.
Use this command to display configured items, MLAG peer switch state, MLAG group count, and health-check statistics.
The following command displays information for an MLAG peer switch:
# show mlag peerFollowing is sample output for the command:
Multi-switch Link Aggregation Peers: MLAG Peer : leftBD8k VLAN : isc Virtual Router : VR-Default Local IP Address : 1.1.1.2 Peer IP Address : 1.1.1.1 MLAG ports : 2 Tx-Interval : 1000 ms Checkpoint Status : Up Peer Tx-Interval : 1000 ms Rx-Hellos : 184 Tx-Hellos : 184 Rx-Checkpoint Msgs : 12 Tx-Checkpoint Msgs : 12 Rx-Hello Errors : 0 Tx-Hello Errors : 0 Hello Timeouts : 1 Checkpoint Errors : 0 Up Time : 0d:0h:0m:10s Peer Conn.Failures : 1 Local MAC :00:04:96:11:22:44 Peer MAC :00:04:96:11:22:33 Config'd LACP MAC :None Current LACP MAC:00 :04:96:11:22:33 Multi-switch Link Aggregation Peers: MLAG Peer : rightBD8k VLAN : isc Virtual Router : VR-Default Local IP Address : 1.1.1.1 Peer IP Address : 1.1.1.2 MLAG ports : 2 Tx-Interval : 1000 ms Checkpoint Statu : Up Peer Tx-Interval : 1000 ms Rx-Hellos : 167 Tx-Hellos : 167 Rx-Checkpoint Msgs: 12 Tx-Checkpoint Msgs : 12 Rx-Hello Errors : 0 Tx-Hello Errors : 0 Hello Timeouts : 1 Checkpoint Errors : 0 Up Time : 0d:0h:0m:7s Peer Conn.Failures : 1 Local MAC :00:04:96:11:22:44 Peer MAC :00:04:96:11:22:33 Config'd LACP MAC :None Current LACP MAC :00:04:96:11:22:33
Following is sample output when an MLAG peer has been created but the IP address is yet to be configured:
* switch # show mlag peer switch101 Multi-switch Link Aggregation Peers: MLAG peer : switch101 VLAN : Virtual Router : Local IP address : Peer IP address : MLAG groups : 0 Tx-Interval : N/A Checkpoint Status : Down Peer Tx-Interval : N/A Rx-Hellos : 0 Tx-Hellos : 0 Rx-Checkpoint Msgs : 0 Tx-Checkpoint Msgs : 0 Rx-Hello Errors : 0 Tx-Hello Errors : 0 Hello Timeouts : 0 Checkpoint Errors : 0 Up Time: N/A : 0 Peer Conn.Failures : 0 Local MAC :00:04:96:11:22:44 Peer MAC :00:04:96:11:22:33 Config'd LACP MAC :None Current LACP MAC: 00:04:96:11:22:33
Following is sample output displaying LACP MAC for an MLAG peer:
* switch # show mlag peer switch101 Multi-switch Link Aggregation Peers: MLAG Peer :S2 VLAN :isc Virtual Router :VR-Default Local IP Address :1.1.1.1 Peer IP Address :1.1.1.2 MLAG ports :0 Tx-Interval :1000 ms Checkpoint Status :Up Peer Tx-Interval :1000 ms Rx-Hellos :153379 Tx-Hellos :153895 Rx-Checkpoint Msgs :6 Tx-Checkpoint Msgs :14 Rx-Hello Errors :0 Tx-Hello Errors :0 Hello Timeouts :0 Checkpoint Errors :0 Up Time :1d:17h:45m:8s Peer Conn. Failures :0 Local MAC :00:04:96:11:22:44 Peer MAC :00:04:96:11:22:33 Config'd LACP MAC :None Current LACP MAC :00:04:96:11:22:33 Config'd LACP MACConfigured LACP MAC is the configured LACP MAC using the:
configure {mlag peer} peer_name lacp-mac lacp_mac_address
command.
Config'd LACP MACis shown as None.
Config'd LACP MAC.If LACP MAC is not configured on any of the MLAG peers or if a different MAC is configured on the peers,
Current LACP MACis different from Config'd LACP MAC and is selected from Local MAC/Peer MAC combination.
This command was first available in ExtremeXOS 12.5.
