This command configures TCP connection timeout globally for all TLS servers.
| tls | Specifies Transport Layer Security (TLS). |
| tcp-user-timeout | Specifies the TCP user timeout attribute. |
| seconds | Specifies the timeout in seconds. |
| default | Specifies to use the system default timeout. |
Use the system's TCP user timeout setting.
This is not configurable per server.
The following example sets the TCP user timout to 60 seconds.
configure radius tls tcp-user-timeout 60
This command was first available in ExtremeXOS 31.4.
