Changes the profile that the configured LSP path uses.
| lsp_name | Specifies the RSVP-TE LSP. |
| path_name | Specifies the configured RSVP-TE LSP path. |
| profile_name | Specifies a profile to be applied to the configured LSP path. |
N/A.
This command changes the profile that the configured LSP path uses.
Changing the profile while an LSP is active may cause the LSP to be torn down and re-signaled.The following command configures the switch to apply the LSP profile gold-class to the LSP path sydney-bypass for the LSP aus:
configure mpls rsvp-te lsp aus path sydney-bypass use profile gold-class
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
