This command displays frame-delay information for the given CFM segment.
segment_name |
An alpha numeric string identifying the segment name. |
mep |
Maintenance association End Point. |
mep_id |
MEP-ID. The range is 1-8191. |
N/A.
Use this command to display the delay for the last received frame, the minimum, maximum and average delay, and the delay variance during the current transmission. When the segment name is not specified, only the segments which have valid statistics alone are displayed. When the segment name is specified, that particular segment‘s information, although not present, is displayed.
The following command displays the frame delay statistics for the CFM segment:
show cfm segment frame-delay statistics
Following is sample output for this command:
Segment Name Mep Recent Min Max Mean Jitter Errored
ID Delay Delay Delay Delay Delay Frames*
(ms) (ms) (ms) (ms) (ms)
segment1 ---- 0.000 0.000 0.000 0.000 0.000 0
segment2 100 0.000 0.000 0.000 0.000 0.000 0
200 0.000 0.000 0.000 0.000 0.000 0
segment3 100 0.000 0.000 0.000 0.000 0.000 0
300 0.000 0.000 0.000 0.000 0.000 0
Flags: (*) % of frames beyond alarm threshold in the current measurement window
Total Configured Segments : 3
Total Active Segments : 3
This command was first available in ExtremeXOS 12.3.
The mep id show output was added in ExtremeXOS 15.4.
