Unconfigures authentication service unavailable VLAN on network login enabled ports.
vlan_name | Specifies the name of the authentication service-unavailable VLAN. |
port_list | Specifies one or more ports or slots and ports. If the ports keyword is not used, the command applies to all ports. |
Defaults to all network login enabled ports.
This command unconfigures authentication service unavailable VLAN on the specified network login enabled ports. Authentication service unavailable VLAN is unconfigured on all the network login enabled ports, if no port is specifically mentioned.
