Configures a Web server target with an EMS filter.
| xml_target_name | Specifies the name of the xml notification target. |
| filter-name | Specifies the name of the EMS filter. |
| severity | Specifies the least severe level to send (if the keyword only is omitted). |
N/A.
Use this command to configure a Web server target with an EMS filter. All EMS filters can be applied.
The following command configures the Web server target test2 with EMS filter filtertest2:
configure log target xml-notification test filter filtertest2
This command was first available in ExtremeXOS 12.4.
