Configures the BGP neighbor timers.
| remoteaddr | Specifies the IPv4 or IPv6 address of a BGP neighbor. |
| all | Specifies all IPv4 and IPv6 neighbors. |
| keepalive | Specifies a BGP neighbor timer keepalive time in seconds. The range is 0 to 21,845 seconds. |
| holdtime | Specifies a BGP neighbor timer hold time in seconds. The range is 0 and 3to65,535 seconds. |
The default keepalive setting is 60 seconds. The default hold time is 180 seconds.
You must disable the BGP neighbor before changing the timer values.
This command applies to the current VR or VRF context.
The following command configures the BGP neighbor timers:
configure bgp neighbor 192.168.1.5 timer keep-alive 120 hold-time 360
Support for IPv6 was added in ExtremeXOS 12.6 BGP.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
