This command configures COS extended support on the IP phone. This information will be sent to the IP phone from the ExtremeXOS switch by trust TLV and COS TLV.
| cos_value | COS value range from 0 to 7. |
| port_list | Port list separated by a comma or -"; |
None.
The following example sets the COS TLV value as 4 for port 5 in the ExtremeXOS switch, which will be used by the IP phone to override priority received from PC or the attached device.
configure cdp cos-extend 4 ports 5
configure cdp cos-extend 0 ports 5
This command was first available in ExtremeXOS 21.1.
