Disables Network Address Translation (NAT) rules.
| ip | Specifies Internet Protocol (IP). |
| nat | Specifies NAT. |
| rule | Specifies disabling a NAT rule. |
| rule_name | Specifies the NAT rule to disable. |
N/A.
You must disable a rule to make configuration changes to it.
The following example the disables the IP NAT rule "rule1":
# disables ip nat rule rule1
This command was first available in ExtremeXOS 31.2.
This command is available on the switches that support the IP NAT feature. For information about which switches support this and other features, see the Switch Engine v33.1.1 Licensing Guide document.
