Displays the current RADIUS accounting client configuration and statistics.
mgmt-access | Specifies configuration and statistics for the switch management RADIUS accounting server. |
netlogin | Specifies configuration and statistics for the network login RADIUS accounting server. |
primary | Primary RADIUS accounting server. |
secondary | Secondary RADIUS accounting server. |
index | RADIUS accounting server index. |
N/A.
If you do not specify a keyword, configuration details related to both management and network login are displayed. The output from this command displays information about the status and configuration of RADIUS accounting.
Use the mgmt-access keyword to display only RADIUS accounting configuration details related to management access.
Use the netlogin keyword to display only RADIUS accounting configuration details related to network login.
The following sample output displays RADIUS accounting client configuration and statistics for both management and network login:
#show radius-accounting Radius Algorithm: standard Radius Retries: 3 Switch Management Radius: enabled Switch Management Radius server connect time out: 3 seconds * Switch Management Radius Accounting: disabled * Switch Management Radius Accounting server connect time out: 3 seconds * Netlogin Radius: enabled Netlogin Radius server connect time out: 3 seconds * Netlogin Radius Accounting: disabled * Netlogin Radius Accounting server connect time out: 3 seconds * Primary Switch Management Radius server: Status: Active host name : IP address : 10.51.1.150 Server IP Port: 1812 Client address: 10.50.130.152 VR-Mgmt) Retries : Not Set (Using Default Retry value) Timeout : Not Set (Using Default Timeout value) shared secret : @~|ioBnao`ox#s Access Requests : 0 Access Accepts : 0 Access Rejects : 0 Access Challenges : 0 Access Retransmits: 0 Client timeouts : 0 Bad authenticators: 0 Unknown types : 0 Round Trip Time : 0 Radius server : 1001 Status: Active host name : IP address : 10.51.1.150 Server IP Port: 1812 Client address: 10.50.130.152 VR-Mgmt) Retries : Not Set (Using Default Retry value) Timeout : Not Set (Using Default Timeout value) Realm : Any shared secret : @~|ioBnao`ox#s Access Requests : 11 Access Accepts : 5 Access Rejects : 1 Access Challenges : 0 Access Retransmits: 4 Client timeouts : 5 Bad authenticators: 0 Unknown types : 0 Round Trip Time : 0
The mgmt-access and netlogin keywords were added in ExtremeXOS 11.2.
The primary and secondary keywords, and index variable were added in ExtremeXOS 16.1
