Returns the specified port to the factory default setting of broadcast link.
| stpd_name | Specifies an STPD name on the switch. |
| port_list | Specifies one or more ports or slots and ports. |
All ports are broadcast link types.
If your STPD has the same name as another component, for example a VLAN, you must enter the stpd keyword to specify the STPD. If your STPD has a name unique only to that STPD, the keyword stpd is optional.
If the switch operates in 802.1D mode, any configured port link type will behave the same as the broadcast link type.
In an MSTP environment, configure the same link types for the CIST and all MSTIs.
The following command configures slot 2, ports 1 through 4 to return to the factory default of broadcast links in STPD s1:
unconfigure stpd s1 ports link-type 2:1-2:4
