Enables Bluetooth capability on a switch.
| switch | Designates enabling switch capabilities. |
| bluetooth | Designates enabling Bluetooth capabilities on a switch. |
| discovery | Sets discoverable mode of the switch. Default is enabled. |
| pairing | Sets pairing ability with other Bluetooth-capable devices. Default is enabled. |
By default, discovery and pairing modes are enabled.
Using the command with no options enables Bluetooth capability on the switch. The discovery and pairing options set discoverable mode and pairing ability, respectively.
To disable Bluetooth capabilites, use the disable switch bluetooth {discovery | pairing } command.
To view Bluetooth and discovery/pairing status, use the show switch bluetooth [statistics | inventory] command.
The following example enables Bluetooth capability on a switch:
# enable switch bluetooth
The following example enables discovery mode on a switch:
# enable switch bluetooth discovery
This command was first available in ExtremeXOS 30.3.
