This command resets all configurable interface parameters to the defaults on one or all VLANs.
| vlan all | Unconfigures IS-IS for all VLANs. |
| vlan_name | Specifies a single VLAN for which IS-IS is unconfigured. |
| level [1|2] | Specifies either level 1 or level 2. |
N/A.
None.
The following command resets IS-IS configuration parameters for SJvlan:
unconfigure isis SJvlan
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
