This command sets or clears the password for Level 2 LSPs.
area_name | Specifies the router process for which the password is set or cleared. |
none | Disables level 2 password authentication. |
encrypted | Specifies that the supplied password is encrypted and must be decrypted prior to using it in a TLV. |
password | Specifies a password. Passwords may be up to 254 alphanumeric characters in length. |
authenticate-snp tx-only | If the optional authenticate-snp keyword is included, level 2 SNPs are also authenticated on receive and the password is included on transmission. If tx-only is specified, the password is included in SNPs on transmission, but received SNPs are not authenticated. |
None.
Packets received are authenticated against the configured password and are discarded if the password does not match. Authentication TLVs are included in transmitted level 2 LSPs with the configured password. Only plain text passwords are supported. Although LSPs contain plain text passwords, passwords are displayed and saved in an encrypted form.
The following command sets the domain password to Extreme:
configure isis area areax domain-password simple Extreme
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
