Turns on/off Extreme Loop Recovery Protocol (ELRP) inter-VLAN loop detection.
| inter-vlan-loop-detection | ELRP detects loops between untagged ports on different VLANs on the same switch. |
| on | Turns on Inter-VLAN loop detection. (Default) |
| off | Turns off Inter-VLAN loop detection. |
Inter-VLAN loop detection is on by default.
It is common in networks for you to accidentally inter-connect two different VLANs by looping together two untagged ports (one in each respective VLAN). This type of configuration results in an outage, and it is difficult for the average user to detect.
If desired, you can then include or exclude the inter-VLAN loops to be disabled using the configure elrp-client disable-ports [exclude | include] [ ports | eaps-ring-ports | remote-endpoints vxlan | inter-vlan-loop] command.
The following example turns on Inter-VLAN loop detection:
# configure elrp-client inter-vlan-loop-detection on
This command was first available in ExtremeXOS 30.1.
