Displays statistics information about VPN VRF operation.
| vpn-vrf-name | Specifies the name of a VPN VRF. |
N/A.
This command displays counters that show:
The total route count displayed for this command can exceed the total route count displayed by the show iproute command because the show iproute command displays either unicast or multicast routes, but not both.This command is supported only on VPN VRFs.
The following example displays the counters for VPN VRF "red":
Switch.19 # show counters vr red Num of Current Routes: 4 Num of Routes Dropped: 0 Num of Route Add: 12 Num of Route Del: 6 Num of Current Routes: 10 Num of Routes Dropped: 0 Num of Route Add: 5 Num of Route Del: 2
This command was introduced in ExtremeXOS 15.3.
