Specifies the maximum value for exponentially increasing time interval between retries for an Automation Edge remote VXLAN network identifier (VNI)-device database.
| database | Makes time interval retries remote VNI-database. |
| max-retry-interval | Specifies setting the maximum value for exponentially increasing time interval between retries. |
| retry_interval | Specifies the value for the maximum time interval between retries in seconds. The default is 600. The range is 1 to 3,600. |
If not specified, the maximum retry interval is 600 seconds.
N/A.
The following example sets the maximum retry interval to 800 seconds:
# configure database max-retry-interval 800
This command was first available in ExtremeXOS 31.1 as a demonstration feature.
This command is fully supported in ExtremeXOS 31.2.
