Shuts down PoE power currently provided to all ports or to specified ports.
| all | Disables inline power to all ports on the switch. |
| port_list | Disables inline power to the specified ports. |
Enable.
Disabling inline power to ports immediately removes power to any connected PDs. By default, the capability to provide inline power to all ports is enabled.
Disabling inline power using the disable inline-power command does not affect the data traffic traversing the port. And, disabling the port using the disable port command does not affect the inline power supplied to the port.
Disabling inline power to a port providing power to a PD immediately removes power to the PD.
The following command shuts down inline power currently provided to ports 4 and 5 on a switch:
disable inline-power ports 4,5
This command was first available in ExtremeXOS 11.1.
This command is available on the PoE devices listed in Extreme Networks PoE Devices.
