Disables SNMP community strings on the switch.
| encrypted | Community name is encrypted. |
| enc_community_name | Encrypted community name. |
| community_name | Community name in ASCII format. |
| hex | Provide value in hexadecimal. |
| hex_community_name | Community name in hexadecimal. |
| alphanumeric-community-string | Specifies the SNMP community string name. |
N/A.
This command allows the administrator to disable an snmp community. It sets the row status of the community to NotInService. When disabled, SNMP access to the switch using the designated community is not allowed.
The following command disables the community string named extreme:
disable snmp community hex 61:01
The hex keyword and hex_community_name variable were added in ExtremeXOS 15.6.
