Deletes a configured RSVP-TE profile with the specified profile name.
| profile_name | Specifies a configured RSVP-TE profile to be deleted. |
| all | Deletes all profiles not associated with an LSP, except the default profile. |
N/A.
This command deletes a configured RSVP-TE profile with the specified profile name. If the all keyword is specified, all profiles not associated with an LSP are deleted (except for the default profile).
A profile cannot be deleted as long as the profile name is associated with a configured LSP. The default profile cannot be deleted.The following command deletes the configured RSVP-TE profile named prof598:
delete mpls rsvp-te profile prof598
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
