Unconfigures the sFlow collector.
| ipaddress | Specifies the IP address of the collector to reset. |
| udp-port-number | Specifies the UDP port. |
| vr_name |
Specifies which virtual router.
Note: User-created VRs are supported only on the platforms listed
for this feature in the
Switch Engine v33.1.1 Licensing Guide
document.
This command allows you to reset the specified sFlow collector parameters to the default values.
Both the commands unconfigure ports monitor vlan and unconfigure sflow collector will reset the collector parameters to the default.
The following command removes the collector at IP address 192.168.57.1:
unconfigure sflow collector ipaddress 192.168.57.
This command was first available in ExtremeXOS 11.0.
