Enables IPv6 routing VLANs. If no argument is provided, enables IPv6 routing for all VLANs and tunnels that have been configured with an IPv6 address on the current VR or VRF.
| vlan_name | Specifies an IPv6 configured VLAN. |
| tunnel_name | Specifies an IPv6 tunnel. |
| vr_name | Specifies a VR or VRF. |
Disabled.
When new IPv6 interfaces are added, IPv6 forwarding is disabled by default.
The following example enables forwarding of IPv6 traffic for all VLANs in the current VR context with IPv6 addresses:
enable ipforwarding ipv6
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
