disable dos-protect
disable dos-protect
Description
Disables denial of service protection.
Syntax Description
There are no arguments or variables for this command.
Default
Default is disabled.
Usage Guidelines
None.
The following command disables denial of service protection:
disable dos-protect
This command was first available in ExtremeXOS 11.1.
Platform Availability
