Displays the user-configured banners.
after-login | Specifies the banner that is displayed after login. |
before-login | Specifies the banner that is displayed before login. |
N/A.
Use this command to display specific configured CLI banners.
If no keywords are specified, all configured banners are displayed. To display a specific banner, use the before-login or after-login keyword.
The following command displays the configured CLI switch banners:
show banner
Output from this command varies depending on your configuration; the following is one example:
Before-login banner: Extreme Networks Summit Switch ######################################################### Unauthorized Access is strictly prohibited. Violators will be prosecuted ######################################################### Acknowledge: Enabled After-login banner: Press any key to continue
The after-login option was added in ExtremeXOS 12.5.
