Adds a permanent entry to the ARP table. You must specify the IP address and MAC address of the entry.
| ip_addr | Specifies an IP address. |
| vr_name | Specifies a VR name. |
| mac | Specifies a MAC address. |
If you do not specify a VR or VRF, the current VR context is used.
None.
The following example adds a permanent IP ARP entry to the switch for IP address 10.1.2.5:
configure iparp add 10.1.2.5 00:11:22:33:44:55
