Deletes a static entry from the neighbor cache.
| vr_name | Specifies a VR or VRF. |
| ipv6address | Specifies an IPv6 address. |
| scoped_link_local | Specifies a scoped, link-local address. |
If you do not specify a VR or VRF, the current VR context is used.
This command deletes static entries from the neighbor cache.
The following example deletes a static entry from the neighbor cache:
configure neighbor-discovery cache delete fe80::2315%default
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
